"True" 5 Bar FPR
"True" 5 Bar FPR
whats the difference between a "true" 5 bar FPR and like say a neuspeed one? nuespeed only charges like 80 bucks for one and i've found adjustable 3-5 bar ones for like 120 but i was reading through some posts on AZ and they were telling someone to make sure they get a "true" 5 bar fpr for their setup and it would run them around 200-300 bucks.
o and another question is it even necessary for a pc-16 setup? some people have told me a 5 bar fpr is necessary while others have told me its not [&:]
RE: "True" 5 Bar FPR
i dunno about true but my guess would be that the stock ones can be modded to be 5 bar or close to it....... and maybe a true one is one thats made to be 5 bar to start with and actaully does all 5 bar and if you put that neuspeed junk on your car ill come at you like a spider monkey !!!
ok found an answer for my question. pc16 requires around a 2.8 bar fpr (everyones will be slightly different) so you'll need an adjustable one. also most 5 bar fpr's are crushed 4 bar fpr's and a real one is one that wasn't a crushed 4 bar OEM fpr but rather one that was made specifically to be a 5 bar fpr
