Whistling Noise?
Whistling Noise?
Has anyone noticed a whistling noise from their side view mirrors at about 65-80 mph? I've only had the car a couple weeks, and put a clear bra with mirror film on last week. I didn't notice the whistling noise before, but do now and I'm wondering if the clear bra film is disrupting air flow enough to cause the whistling noise or was it there before and I just didn't notice it. I can barely hear it with the window up, but it can be loud with the window cracked or all the way down. It also doesn't always happen, only sometimes. If I stick my hand out to disrupt airflow around the mirror, the noise stops. Anyone else noticed this and do you have the clear bra film on the mirrors?
RE: Whistling Noise?
ORIGINAL: wonka
Check the groove located in the mirror housing between the rear and front sections. It should be properly moulded or else that usually causes some noise. Maybe you could also try filling your side view brackets with more insulation and see if it cures the problem.
ORIGINAL: Shazam!
i noticed some noise while riding on the interstate today but only noticed it cuz i had the radio off (which is something i don't think many folks do). don't find it especially unusual for any car...
my windows were closed, but it was the sound that slightly resembled a window that's not FULLY closed. maybe we aren't talking about the same thing though after all.
ORIGINAL: BearTrap
Then we're not talking about the same noise. I've had 18 previous cars and haven't had this type of noise in any of them. Did you have your window open at all? I barely notice it with the window closed but it can be very irritating with the window open or even cracked open.
ORIGINAL: Shazam!
ORIGINAL: BearTrap
Thanks for the suggestions. When I stick my hand out the window and put it between the mirror and car, it doesn't help. So I don't think the idea of the insulation will work. However, when I checked the seam like you suggested, the two parts weren't perfectly aligned, so I put some electrical tape over the seam. I also put some tape over the two screw holes just incase that might be doing it. I'll find out tomorrow if this fixes the problem. Thanks again.
ORIGINAL: Vix_Turbo_A3
BearTrap,
Where did u get your clear bra decals and how much did you pay for it? Can you remove them on and off?
BearTrap,
