Static noise rear speakers after Market stereo
Old 01-18-2011 | 01:54 PM
danderton's Avatar
Default Static noise rear speakers after Market stereo
Hi guys
I have Discovered others have had this problem but I can't find a solution. I have just brought an A3 and loving it. Except I get an annoying static noise from the rear speakers(i think it's the passenger side) it's definitely an issue with rear speakers as if I remove the wiring loom for the rear it disappears.
The rear speakers have there own remote turn out so I suspect the issue is somewhere along the line with that( only a guess). I don't have the rear multi changer connected as others have said this can cause the issue
So the question is how Do I fix it before I go mad!
Thanks
Old 01-20-2011 | 05:34 PM
danderton's Avatar
Fixed! AUtolead conversion was causing issue. Apparently theyre leads aren't compatible with some cars!
no more noise
Old 04-07-2011 | 10:20 AM
Kyle04's Avatar
Hi mate,
how did you fix this problem, did you have to buy a new lead?
rowfour
05-07-2014 03:57 PM
mjb2012
12-05-2012 10:20 AM
sci_83
07-07-2012 08:47 AM
jonjepko
05-24-2006 05:16 PM
