Radiator Fan Won't Stop.. HELP
Got I3 flash update Thursday, took a run through the hills the following Saturday and now my radiatory fan (the one closer to the passenger side) keeps running after car is turned off.
I let it run assuming it was on to cool engine. I grab lunch, come back an hour or so later and the fan's still running and it drained my battery! [:@]
Had no choice but to use jumper cables and allowed engine to recharge the battery. Then I disconnected the negative terminal on the battery in order to keep the fan from draining me dry before I had to service on Monday.
Can anyone help??? I spoke to an Audi service tech, but he was no help in helping me locate a relay/fuse that I can remove to stop fan. Neither did he help me find the fan's switch to temp. turn it off.
I'd rather remove/replace fuses than having to pop the hood to connect/disconnect my battery each time. [&o]
Thanks in advance.
Thanks in advance.
RE: Radiator Fan Won't Stop.. HELP
ORIGINAL: MYH8for405
Thanks in advance.
Thanks in advance.
Thanks Chef. How's your A3 coming along? Last I read it was getting painted?
If I ran my businesses like body shops do, then I'd never have any customers and the world would die of starvation. LOL
Cheers!
Update: I just came back from the dealership. They ran a few tets on the ECU and found no fault codes -- service rep. said he had no idea and gave me a A4 loaner. Will find out by EOD I suppose.
neomaxddr
03-28-2009 08:16 PM
cvacc411
01-29-2009 05:58 PM
