Multiple Codes
Old 04-16-2014 | 09:27 AM
phdnpcpi's Avatar
Default Multiple Codes
Hi all, I drive (or drove) a 2007 A3 2.0t s-line with the BPY engine code.
138k miles, all maintenance intervals, last timing belt change was 100k other than that no real issues.
OK, so the other day on the highway @ about 70mph with the cruise set my car shuts off, I coast to a stop and after realizing the car wasn't going to start i had it towed home.
Found that the Timing Belt was shredded, I mean it looks like someone took a bag of beef jerky and poured it into the timing belt cover. Being the skeptic i am i pulled everything apart and checked valves, head pistons, cams all the normal stuff one checks when they assume their TB snapped, especially on these motors.... nothing, not so much as a scratch!
So i go put everything back together and attempt to start the car and well i have a multitude of vag codes, I am hoping someone can help me decipher just what the F is happening and what i can do to diagnose.
I have done most all of the common sense things so im not gonna list every step i have taken but from what i can tell the car is not sending fuel to the motor, sounds like the pump is priming, i have the back seats out and can hear it running, it is getting spark, verified that by pulling a coil pack and watching the plug fire. Beyond this im a little stumped
Here is the scan from vcds:
Tuesday,15,April,2014,22:35:00:57138
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Dealer/Shop Name: 2130
VIN: WAUHF78P87A065742 License Plate:
Mileage: 222620km-138329mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUHF78P87A065742 Mileage: 222620km/138329miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 P HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: --H14--- Serial number: AUX7Z0F7FNS08M
Coding: 0103010A1C070160
Shop #: WSC 09223 444 84432
VCID: 3F874F2B6EA28EE6A2D-806A
1 Fault Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 C HW: 02E 927 770 AE
Component: GSG DSG 070 1125
Revision: 04507000 Serial number: 00000608090419
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 142DB08737A4BDBE2FF-8041
No fault code found.
Address 03: ABS Brakes Labels: 1K0-614-517-MK60-F.lbl
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H13001
Coding: 0053890
VCID: 68D5B4775BACE95E337-803D
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
Component: KlimavollautomatH18 0300
Revision: 373905 Serial number: 8P0820043M
Shop #: WSC 02130 213 02130
VCID: 36692A0F41984FAE71B-8063
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 135
Mileage: 222620 km
Time Indication: 0
Date: 2014.04.15
Time: 00:00:41
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006111129
Coding: 018C4F01C0141019000F0064190032640009FE1F641200
VCID: 40854CD7135CF11EDB7-8015
Subsystem 1 - Component: Fehler Lin-Slave 01
4 Faults Found:
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 175
Mileage: 222619 km
Time Indication: 0
Date: 2014.04.08
Time: 16:11:00
Freeze Frame:
OFF
Voltage: 11.60 V
OFF
ON
OFF
OFF
OFF
02071 - Local Databus
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 222619 km
Time Indication: 0
Date: 2014.04.08
Time: 16:04:00
Freeze Frame:
ON
Voltage: 11.45 V
ON
ON
OFF
OFF
OFF
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 10
Reset counter: 166
Mileage: 220894 km
Time Indication: 0
Date: 2014.03.17
Time: 12:04:00
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 28
Reset counter: 135
Mileage: 222619 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.50 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 A HW: 8P0 959 655 A
Component: Airbag 9.41 H12 3890
Revision: 91H12389 Serial number: 0035W0G01T77
Coding: 0032605
Subsystem 1 - Part No: 8P0 910 339
Component: BF-Gewichtsens. 001 0020
Subsystem 2 - Serial number: 3BF5H
Subsystem 3 - Serial number: 0001.01.000000100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB403C352B0Jÿ†63
Subsystem 5 - Serial number: 352B0Jÿ†6342DRB403C48B8B+ÿ†63
Subsystem 6 - Serial number: 48B8B+ÿ†63528RB40175925BKÿ†63
Subsystem 7 - Serial number: 5925BKÿ†63628RB4017589D3Rÿ†63
Subsystem 8 - Serial number: 589D3Rÿ†63729RB4018C11DEXÿ†63
Subsystem 9 - Serial number: C11DEXÿ†63829RB4018C117BPÿ
Subsystem 10 - Serial number: C117BPÿ
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H34 0070
Coding: 0012142
VCID: 418349D31856F816D49-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 H HW: 8P0 920 981 H
Component: KOMBIINSTR. VDO H18 0560
Revision: D0H18002 Serial number: 2247F002003015
Coding: 0000259
VCID: 3D7B352364AE9CF6B01-8068
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 J HW: 1K0 907 951
Component: J533__Gateway H12 0160
Revision: H12 Serial number: 32001068028483
Coding: 3F3F034207002102
VCID: 2E59026FB9C8776E39B-807B
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18002 Serial number: AUX7Z0F7FNS08M
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0001177
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346D100757E45DBE4FF-8061
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 D
Component: 02 KSG H04 0050
Coding: DBC003403F7F870FC00F047301
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674696594863
VCID: F1E35913E876A896E49-80A4
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0001176
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 K HW: 8P0 035 186 K
Component: concert II US H52 0460
Revision: 04S Serial number: AUZ5Z6F6031790
Coding: 0402004
VCID: 3A713E3F7580ABCE953-806F
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0001176
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0001176
End ---------------------------------------------------------------------
DJLishis
B7 Models
12-18-2013 01:24 PM
JPizano23
09-23-2011 11:36 PM
dandefronzo@gmail.com
10-22-2010 11:47 AM
jangalang
11-10-2009 12:17 PM
SAudi
01-01-2008 07:22 AM
Quick Reply: Multiple Codes
