Help with OEM iPod adapter
Old 09-01-2007 | 04:43 PM
99cobra66's Avatar
Default Help with OEM iPod adapter
Hey everyone... I'm new to the Audi forums b/c I just got a 2007 A3 S-line
anyways, I just bought an OEM ipod adapter and have a few question:
1. I have a Symphony II radio with an indash changer... will I be able to use the cd function after I install the adapter?
2. how do I remove the glove box so i can run the wires to the inside of it.
thanks in advance!
Old 09-02-2007 | 05:42 PM
99cobra66's Avatar
Default RE: Help with OEM iPod adapter
anyone?
Old 09-02-2007 | 08:28 PM
2k S4's Avatar
It uses the CD changer controls & input, so you loose the CDC. Glove box no idea, but you should not have to pull it out, only the radio.
Old 09-02-2007 | 08:50 PM
99cobra66's Avatar
so once I install it, I will not be able to use my in-dash CD player what so ever?
Old 09-03-2007 | 09:39 AM
threshold's Avatar
I think you only loose the capacity for the glove-box 6-disk changer. The single disk in-dash CD should work just fine.
Old 09-03-2007 | 02:33 PM
99cobra66's Avatar
hmmm... well i have the 6 disc in dash, will I be able to use it as a single CD player?
Old 09-03-2007 | 03:38 PM
Jeratain's Avatar
There's lots of threads on this subject if you do a search on it. You might even find an article on installation over at DIY: http://www.audidiy.com/a3.html
My understanding is that if you have the 6CD In-Dash changer, you can install the iPod adapater just fine and use both. The only catch is that if you have Satellite radio installed, you will have to give that up for the iPod. However, there is a splitter you can buy that will let you use the in-dash changer, the Satellite, and the iPod adapter.
Old 09-03-2007 | 03:44 PM
ScareGlower's Avatar
I was thinking about getting an iPod adapter installed as well - but I heard it sucks.
Old 09-04-2007 | 02:23 AM
99cobra66's Avatar
thanks... well that would be great... i dont care about the SAT, so as long as i could keep the CD player I would be happy.
Old 07-06-2008 | 10:24 PM
empressofromania's Avatar
Default ipod adapater not working
I just bought an A4 with an ipod adapter. When I put the ipod in the adapter, the ipod sets itself to "pause" and won't play any music. No matter how I set the ipod, the results are the same.
Any suggestions?
