Custom Installed Radar Detectors...
Old 01-08-2008 | 10:39 PM
BearTrap's Avatar
Default RE: Custom Installed Radar Detectors...
ORIGINAL: Chef
There is a rubber boot down where the steering column meets the firewall. That is the best place to come through, IMO.
Cheers!
That's where I went through the firewall, just be aware there is a rubber cover that comes off after unscrewing three bolt covers.
  #22
Old 01-09-2008 | 01:22 PM
spencerjw's Avatar
Not to hijack this thread but for those of us in states where we can have detectors and aren't concerned about it getting stolen...anyone have advice on hard-wiring it into the lighting in your roof or something like that?
I had done this with my cheap(er) Cobra in my '04 Passat. I had it wired to the lights so that it was always-on. Only issue is that when I locked or unlocked the doors the car flashes the interior lights causing a break in that always-on connection and turning the unit on and off. not a big deal, but kind of point defeating.
Anyone have advice on hard wiring a window mounted unit?
  #23
Old 01-09-2008 | 04:36 PM
AManCalledE's Avatar
I think I remember seeing where somebody had tapped it into the OpenSky fuse.
  #24
Old 01-11-2008 | 01:50 AM
BAMF's Avatar
spencer, try www.audidiy.com - there are a few write-ups on hard wiring a radar detector to a 12v lead that is accessible under the sunroof control panel. I'm not sure if it is a constant or switched 12v though. Most of them are for a Valentine V1, but it will apply to any radar detector.
Otherwise, you could always run the wire under the headliner and down the left A-pillar directly to the fuse box. The rear wiper fuse will work fine and is switched (turns on and off with the ignition).
sluggerjd
05-10-2009 06:36 PM
jakej
11-25-2007 10:43 PM
diablo9861
03-12-2007 02:56 PM
betz470
06-01-2005 04:57 AM
apg96
03-07-2005 09:32 PM
