Air conditioning not cold..
Old 07-29-2013 | 11:48 AM
andrew456's Avatar
Default Air conditioning not cold..
Hi all, got a 2007 A3.
Air con is blowing out air but it isn't cold (assume just outside temp). Assumed it just needed regassing, but garage said that gas was near enough full and the pressure was fine (eliminates a leak?). They thought it was electrical. Took it somewhere else and they did full electrical test and said the only problem was the smaller of the 2 cooling fans wasn't working and that would need replacing. Have replaced that myself and nothing has changed. At a bit of a loss now, any other suggestions?
Thanks
Old 07-29-2013 | 12:33 PM
sheldon's Avatar
Some of the Hvac codes get stored. Have you pulled codes yet (like with Vag-Com)? That might help pinpoint the issue
Old 08-08-2013 | 08:41 PM
jschrauwen's Avatar
From: Frankford, Ontario. 08 A5, 00 A4, 90 TT 300ZX, Ducati TT2
Are there are other physcial checks one could do? Fuses, relays???
djmilleroh
07-13-2010 10:01 PM
motojoeis01
12-20-2009 11:22 AM
1.84life
06-20-2008 01:21 AM
quattro/2.8
09-08-2006 02:17 AM
Quick Reply: Air conditioning not cold..
