a3 willnot turn over heeeelp !
Old 09-09-2014 | 05:29 PM
max16's Avatar
Default a3 willnot turn over heeeelp !
hi,
any help would be appreciated,
battery was getting flat on my 2007 a3 1.9 diesel after cranking (after engine change) so went to jump it but now will not crank !
battery now fully charged but no power to solenoid on starter upon cranking position on key
done a bit of research appears audis will crank over even with immobilizer probs unlike other makes (as i initially thought this was the problem)
do these have a starter relay ?
are the ignition switches prone for failure as this is the only thing that would make any sense even though its only done 60k
no fault codes showing
thanks in advance
xerokill00
08-18-2007 05:49 AM
a4_avant
06-20-2007 03:03 PM
grapejuice
01-09-2006 09:03 PM
a4BRZLowrider
12-31-2005 01:34 PM
paliracer
02-21-2005 03:15 PM
Quick Reply: a3 willnot turn over heeeelp !
