a3 rear wiper motor
Old 12-30-2010 | 10:18 AM
malcolmharvey2's Avatar
Default a3 rear wiper motor
After the recent cold spell the rear wiper motor on my 04 - A3 is leaking washer fluid and is now running continusly - I guess something has burst inside.
I have seen some repair kits for older cars, does anyone know if one is available for this model and is it practical to try this or should I just change it completey (eitrhyer second hand or new)
I have not taken the motor off the car yet so any advice would be great.
Old 08-26-2013 | 09:05 AM
np1974np's Avatar
I would suspect that you have used water & not washer additive which contains antifreeze ,hence the water in the fluid passage in the washer motor has fractured causing leaks. undo the trims at the rear & get someone to operate the washer to identify the leaks. May need to replace the whole of the motor assembly as the nozzle is a possible suspect. Hope this helps. regards np1974np
guesty
04-01-2014 06:08 AM
naoufelghellam
06-30-2010 01:46 AM
99b5avant
07-13-2009 03:22 PM
jtheobald
09-04-2006 11:33 PM
joeturbo
08-11-2006 09:56 AM
