FJ NJ: BBS RK-II (RK-501) 18" Two Piece Wheels and Tires
For sales are a set of four rims and tires that were on my 2000 S4.
The bad:
I hit a pot on the GSP and damaged two of the rims. One is bent and does not hold air. The seam between the center of the rim and the outer band has been broken. The other was bent on the lip a little and has the clear coat peeling.
I took them to proformance (http://www.proformanceindustries.com/) and they said they could be repaired.
The good:
Two rims are in good shape with no curb rash. They have some flecks in the picture which I think is the clear coat, they could use a polishing. One tire is new (on the broken rim, the tire is okay) and the rest have a lot of tread left.
I am looking for about $750 for the set. I am in north NJ and would like to do pick up only.
Hi-res pictures here:
http://www.s-ca.com/gallery/main.php...avId=x26d71af5
The bad:
The good:
paulywalnuts446
14
02-23-2020 05:20 PM
bigatstyle
11-09-2012 08:29 AM
tdied
07-05-2012 09:23 PM
Benj
05-21-2010 05:58 PM
AudiSport44
07-29-2009 01:54 AM
