WTB ABS Control Unit for B5 A4 1.8T
Audi Part #8D0 614 111 D
Bosch Part no- 0265 218 020
Need one asap, my current one is causing the front left caliper to lock up.
Please help!
Please help!
Im still looking for this if anyone knows where I can get one. I found two on ebay but they are in the UK and the sellers wont ship to the US. It seems they may come from 1996-2000 A6 as well.
I have one unit in working condition, except that one of the relays is shut (about $25 to buy a new one on ROCKAUTO.com for example). I bought whole unit just yesterday but it came out that "stealing" a relay did the trick to mine. I had different symptoms than your problem, sounds like you have a stuck solenoid valve which mandates rebuild or replacement.
I bought the pump for $125, I was told it is from 90k car, it looks pretty decent. I can make a picture of it if you want. Original thread: http://forums.vwvortex.com/zerothrea...ostid=54787158
The unit is a complete part, including the solenoids (where electrical connector is located) and pump itself. You will have to disconnect hydraulic lines when replacing since I don't think that solenoid part can be separated from the pump itself. Easy job.
This model of ABS is a two part system. ECU (controller) is located inside of car, most likely under rear seat (that's the case with my 1998 A6 Quattro) and has a different part # altogether. I believe that latter models of ABS systems have the ECU inside the unit, like Bosch 5.3. If you need ECU, I also have that (also bought unnecessarily) and would part with it for $70. The second part is the pump you listed in your thread, it is located in engine compartment.
I will part with it for $100 plus shipping, probably about $10 USPS. Otherwise I will wait until mine really goes out
Let me know.
Let me know.
