2001 s4 not together. tial 770 kit.
FOR SALE. for the right price. Not trying to part out with it because the build might happen unless the offer is right.
Its 2 am right now insomnia has kicked in and im just going to put whats for sale. Pictures will come tomorrow.
HEAD STUD KIT, AUDI 2.7T RWE-1051 1
HEAD GASKET, 2.7T UP TO 83.5MM BORE 2 37.50
OEM VALVE COVER GASKET SET, ONE VALVE COVER, AUDI 2.7
TIMING BELT KIT
2.7T HIGH LIFT VALVE SPRING SET WITH RAISED INSTALL HEIGHT, INCLUDES TI
RETAINERS.
745.00 745.00T
MAIN STUD KIT 2.7TT, SAME LENGTH STUDS, LATE 2001 RWE-2015 1 345.00 345.00T
PAUTER 2.7T ROD SET 1 1,275.00 1,275.00T
COATED MAIN BEARING SET, GLYCO, AUDI V6
AUDI V6 ROD BEARING SET, COATED
JE FORGED PISTON SET, 2.7T, 82.5MM BORE, 86.4MM STROKE, 9.0:1
COMPRESSION
RATIO
BOTTOM END BORE/ASSEMBLY
TIAL GT TURBO KIT, INCLUDES ALL COMPONENTS AND UPGRADED GARRETT GT
TURBOS FOR 770HP, DOES NOT INCLUDE INLET PIPING KIT
INLET PIPE SET FOR TIAL 605/770 TURBO KIT
2.7tt Tilton flywheel for 01E applications with 2-disc cerimetallic, or 3-disc sintered iron clutch
kits.
TILTON PRESSURE PLATE FOR TRIPPLE DISC SINTERED IRON 7.25" CLUTCH KIT, 950
ft/lb RATING.
1 750.00 750.00T
TILTON 2 PLATE CERAMETALLIC CLUTCH PACK FOR 01A/01E SPLINE FOR AUDI/VW
TRANSMISSIONS
THROW OUT BEARING ASSEMBLY FOR 7.25" RACE CLUTCH KITS IN AUDI 01A/01E.
TILTON RELEASE BEARING, INCLUDES BILLET ALUMINUM HOUSING
SINGLE 044 SURGE TANK, FP34, TANK INCLUDES q3-12MM PLUGS W/ WASHERS,
PUMP
***NIPPLE FITTINGS/ CLAMPING FEET***
72LB OR 750CC EV14 BOSCH INJECTOR
INJECTOR ADAPTER TO CONVERT S4 2.7T FUEL RAIL TO RS4 INJECTORS 6
INJECTOR CONNECTOR ADAPTER, BOSCH TO USCAR, FOR GENESIS 750CC
INJECTORS
RS4 SILICONE MAF HOSE, BLACK
85MM 2.7T MAF, HOSE CONNECTIONS, HO MAF 1
HO MAF SENSOR/ CONNECTOR
034EFI CHIP TUNING, B5 S4 - TIAL 770 KIT, BASEMAP 1
DOWNPIPE PAIR, B5 S4 3" TIAL 770
WITH WASTEGATE REROUTES BACK TO DOWNPIPE
battery relocation kit, electric fan kit as well.
Body is in 8/10 shape. interior 8.5/10
all black leather.
ASKING 25,000 but throw the offers at me here.
im a young fella and need to move on with my life right now and this project might take a little to long. Dont low ball me this is my dream car and getting rid of it breaks my heart to pieces. but if it has to be done it has to be done. i will check up on here tomorrow. Take Care, Dylan.
TIMING BELT KIT
RETAINERS.
745.00 745.00T
COMPRESSION
RATIO
kits.
ft/lb RATING.
1 750.00 750.00T
TRANSMISSIONS
PUMP
INJECTORS
all black leather.
also have jhm intercooler FMIC and meth kit.
willing to part out now....... 985 503 0068
Dylan Cure
07-13-2014 09:09 AM
Dylan Cure
06-18-2013 03:36 PM
