Kenwood 7202 amp and Infinity Kappa Perfect 12.1 sub
Thinking about upgrading my stereo system, so I've gotta get rid of this stuff to afford something newer. Both items are in great condition and have never been abused. Both are just a little over a year old. The amp is a Kenwood 7202 2-channel amp with 150 watts RMS per channel, or one bridged 460 watt RMS channel. The sub is a crystal clear Infinity Kappa Perfect 12" sub w/ sub-box. This thing REALLY bumps and has an incredibly clear, crisp sound. The system originally cost me about $400 for everything. Selling for $200 firm plus shipping, if necessary. I'd rather sell locally. This is a great system for anyone looking for a cheap, yet quality sound upgrade. Here are the specs:Kenwood 7202 Amp
ยป two-channel car amplifier
ยป 150 watts RMS x 2 at 4 ohms (230 watts x 2 at 2 ohms)
ยป 460 watts RMS x 1 bridged output at 4 ohms (4 ohm stable in bridged mode)
ยป high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
ยป selectable bass boost (0-18 dB at 40 Hz)
ยป cooling fan
ยป MOSFET power supply
ยป Tri-way capable (Tri-Way Crossover required)
ยป CEA-2006 compliant
ยป preamp- and speaker-level inputs
ยป preamp outputs
ยป fuse rating: 40A x 1
ยป 8-gauge power and ground leads recommended โ wiring and hardware not included with amplifierInfinity Kappa Perfect 12.1 sub
# 12" 4-ohm subwoofer
# aluminum cone with high-roll butyl-rubber surround
# massive cast-aluminum basket
# suitable for free-air use (handles up to 175 watts in free-air applications)
# power range: 75-350 watts RMS (1,400 watts peak power)
# frequency response: 18-200 Hz
# sensitivity: 96 dB
# top mount depth: 6-1/8"
# sealed box volume: 1.0 cu. ft.
# ported box volume: 1.75 cu. ft.PM me with any questions
ยป cooling fan
ยป preamp outputs
mbz300sdl
12-03-2007 01:20 PM
A4 the Quattro
07-06-2006 10:21 PM
betz470
10-14-2005 01:40 AM
