Central Locking Pump '99 A4
I have a central locking pump unit that has a broken fan if anyone is interested.
RE: Central Locking Pump '99 A4
Hey Scott,
Have you still got the pump?
If you have does the rest of it still work? Like the motor still spins over
when it gets a signal?
Can you upload a photo and the part number?
Appreciate it, might be the solution to mine.
Thanks
Thanks
Not sure if it will work on your model. The Part No. 8L0-862-257-N
Electronically it works perfect. It was replaced because the impeller shattered.
I've tried to upload images and I'm getting an error message.
Send me an email that I can reply to and I'll forward the images.
Thanks
Thanks
If you can send the images to kitj@i4free.co.nz I'll check them out.
Thanks
Thanks
i have one as well that is broken from a 2001 a4
Are you able to read its part numbers and post them?
If you can email me an image (address above) Ill be able to see if
I can use it. Thanks.
I'm looking for one too for my 1999.5 A4 1.8t, 8L0-862-257-N. I don't know if its a broken fan or burnt out. When i went to check out the pump the sound dampener was soaked and there was a puddle of water at the bottom, god knows how water got in. The motor still turns over when i press my remote so im thinking its the fan, but the water being there makes me think twice. Either way im in need of a new one if anyone can help.
MPLSChase
08-11-2009 11:30 AM
