MASSIVE facelift part out
Everything is off my 2001 a4 1.8t quattro with a manual transmission. Car is brilliant black exterior with onyx interior.
everything is OBO
Located in central florida
Engine and driveline:
shifter box/shift linkage-$150
radiator support-$150
radiator-$100
K&N panel air filter-$25 shipped
altenator-$50
AC compressor-$100
AC condenser-$95
rear axles-$45 shipped each
manual driveshaft-$130
tranny mounts-$10 each
rear differential manual-$150
pedal assembly-$75 shipped
crank pulley/engine dampener-$65 shipped
P/S pulley-$25 shipped
stock airbox-$55 shipped
crank/flywheel/engine speed sensor-$25 shipped
oil level sensor-$30 shipped
axle and trans heat shields-$15 shipped each
condensor fan (in front of radiator)-$55 shipped
electric fan in core support-$45 shipped
cam gear-$15 shipped
coolant tank-$20
PS tank-$10 shipped
ABS tank-$10 shipped
vacuum canister under DS fender-$10 shipped
washer fluid tank-$40 shipped
bumper squirter pump-$10 shipped
windshield squirter pumped-$10 shipped
suction pump under DS rear wheel well with filter-$35 shipped
charcoal canister box under spare wheel tub-$50 shipped
stock 1.8t intercooler-$
Exterior:
hood-$150
bumper-$150
shaved doors-$600
fenders-$75 ea
trunk-$150
gas cap-$10 shipped
gas cover-$20 shipped
fender liners-$35 shipped each
fender side marker lights-$15 shipped
ecu box upper-$15 shipped
cabin air filter assembly 3 piece-$20 shipped
wiper blade metal arms-$20
trunk hinges-$25
trunk shocks-$20
hood strut/shock-$20 shipped
headlight mounting tabs/brackets (near rad on core support)-$20
front or rear bumper shock-$45 shipped
PS cooler loop assembly-$35 shippedSOLD
front chassis oem strut bar and side brackets-$75 shipped
front hood hinges-$20
rear bumper side mounts-$15 shipped pair
front bumper mounts-$25 shipped pair
horns-$13 shipped each or $20 shipped pair
rear door black shiny metal triangle pieces in doors-$15 shipped pair
door strykers, latches-$20 shipped for set of 4
door hinge set-$45 shipped
door bear claw latch (mounts in the door)-$25 shipped each
wiper motor-$40
wiper linkage-$30 shipped
wiper and motor linkage-$65
trunk seal-$10
hood seal on core support or firewall (rubber)-$10
Interior/Electrical:
Onyx leatherette seats(COMPLETE: driver&pass fronts, rear back, rear bottom, 2 rear sides, and 4 headrests)-$400
**NOTE: Driver seat bottom does have that patented Audi rip**
central locking pump-$75 shipped
gauge cluster(106,xxx)missing some pixels-$125
steering column-$125
steering wheel w/airbag-$125
clockspring-$45 shipped
wiper/stalk/turn signal unit-$45 shipped
dash-$100
facelift center console-CHECK MY OTHER AD
shifter surround/shifter boot-CHECK MY OTHER AD
facelift center armrest console-CHECK MY OTHER AD
e brake- CHECK MY OTHER AD
HVAC-$65
blower motor-$50
heater core-$50
fan control unit module-$45 shipped
oh **** handles-$20
airbag module-$60 shipped
fog light module-$25
complete(F&R) black seat belt set-$70 shipped
6 piece brushed aluminum trim set-$200 shipped
Pass side airbag-$40 shipped
Side curtain airbags-$40 shipped each
interior carpet-$50
seat rail covers(8)-$25 shipped
low pair of kick panels black-$30 shipped pair
lower dash DS knee bolster-$40 shipped
complete glove box-$45 shipped
glove box strut-$15 shipped
dash vents (sides)-$15 shipped each
fuse panel cover DS-$15 shipped
fuse panel cover PS-$15 shipped
miscelaneous relays-$8 shipped ea
aluminum support under dash-$55 shipped
airbag module under carpet in front with yellow connector-$13 shipped each
CD changer-$50 shipped
interior trunk carpeted sides-$15 shipped each or $25 shipped for pair
interior trunk floor carpet-$15 picked up or $45 shipped
trunk spare tire hold down-$10 shipped
rear plastic trunk cover on back of trunk going the width of it-$45 shipped
cubby hole side tray in trunk-$13 shipped
carpeted side interior light-$7 shipped
dead pedal-$13 shipped
fuel pump black cover-$7 shipped
fuel pump blue in/out cover-$10 shipped
fuel fump screw on cover ring-$10 shipped
cargo net-$35 shipped
hood latch (on rad support)-$35 shippedSOLD
hood latch release cable and pull-$20SOLD
Suspension/Brakes/Wheels/Tires:
abs module-$100 shipped
rear uprights with good hubs and bearings-$75 shipped each
rear upright with no hub or bearing-$45 shipped each
power steering rack with inner and outer tie rod ends-$175
Power steering rack with no outer tie rod ends-$150
Front control arm set-$75 shipped
rear upper shock hats with arms-$25 shipped each
rear upper shock arms-$20 shipped
rear lower control arm-$20 shipped each
rear subframe-$60
front subframe-$60
front and rear sway bar set with bars, end links, bushings and brackets-$85 shipped
rear sway bar set with bar bushings, brackets and end links-$80 shipped
rear diff carrier bracket with stock bushings-$25 shipped
rear diff mount stock-$25 shipped
rear diff mount front mounting bracket-$15 shipped
upper triangular hats on front struts-$10 shipped each
rear tie rods-$25 shipped pair
stock tranny mounts-$12 shipped each
brake master cylinder-$60
brake booster-&60
Miscelaneous items:
Tial 38mm wastegate w/big blue spring-$160
Aeromotive adj. fuel pressure regulator(BNIB)-$160 shipped
RC 750cc injectors(BNIB)-$400 shipped
RC 1200cc injectors(BNIB)-$400 shipped
trickflow fuel filter(BNIB)-$80 shipped
MSD coils GM style(BNIB)-$55 shipped each
AEM 5.2 bar MAP sensor(BNIB)-$155 shipped
Autotech adj. cam gear for 06A(BNIB)-$110 shipped
Derale econo-cool oil cooler PN#15830(BNIB)-$135 shipped
Denso Iridium ik27(4)-$60 shipped
AEB intake manifold-$50
everything is OBO
radiator-$100
altenator-$50
AC compressor-$100
AC condenser-$95
coolant tank-$20
PS tank-$10 shipped
Exterior:
hood-$150
bumper-$150
shaved doors-$600
fenders-$75 ea
trunk-$150
gas cap-$10 shipped
trunk hinges-$25
trunk shocks-$20
wiper motor-$40
trunk seal-$10
dash-$100
HVAC-$65
blower motor-$50
heater core-$50
oh **** handles-$20
interior carpet-$50
rear subframe-$60
front subframe-$60
brake booster-&60
Miscelaneous items:
bump it up
Do you have the driver side headlight washer?
bump it up
bump it up
Obo bump
Lets go! best offers
Come one guys! He's a great seller!
Thanks man! I appreciate the feedback!
