B5 A4 *PARTING OUT* EXTREMLY CHEAP
Prices do not include shipping
Pics Available upon Request.
If you don't see it….Ask, I probably have it.
motocrossracermichael@hotmail.com
[/align]1996 A4 *79k* miles
Engine
Tranny -Automatic - $350
Engine 2.8L79k-$750.
Throttle Body - $50
Idle Control valve - $30
MAF w/Sensor - $65
[/align]Power Output Stage (POS) - $75
Coil Packs - $30. each
Rail w/Injectors - $50
Engine Mounts - $40/Ea
Alternators - $50
Power Steering Pump - $40
Brake Booster - $50
Brake Master Cylinder - $50
Brake Fluid Resevoir - $15
Differential - $75
Coolant Resevoir w/sender - $30
Wiper Motor - $30
Wiper Linkage - $40
Washer Spray Nozzles (Main) - $15/Both
Washer Spray Nozzles (Headlight) - $40/Ea
Washer Fluid Resevoir - $40
Washer Fluid Pump (Main) - $40
Washer Fluid Pump (Head Light) - $40
Shift Linkage (5sp) - $40
Air Filter Box - $40
Air Filter Box Ducts - $20
Fuel Pump - $75
Fuel Sending Unit - $30
Drive Shaft w/Carrier Bearing - $100
Clutch w/Flywheel - $150
Brakes/Suspension
ABS Module (P/N 8D0 614 111 B) - $70
Brake Calipers w/Carriers - $40/EA
Brake Booster - $25
Brake Master Cylinder - $20
Front Rotors - $15/Ea
Rear Rotors - $15/Ea
ABS Speed Sensors $40/EA
Tie Rod Assys- $40/ea
Control Arms $40/ea
Differential - $100
Axle Rear - $45/EA
Axle Front - $45/EA
Rear Knuckles/Knee Assy w/Hubs - $50/Ea
Exterior/Body/Lighting
Instrument Cluster - $100
Headlights - $60/Ea
Corner Markers - $30/Ea
Driver's side Mirror Housing (No Glass) - $30
Passenger's side Mirror Housing (No Glass/Snubby) - $30
Euro Plate Trunk - $150 (Black, has some scratches and indents form a bike rack)
Hood - $150
Exterior Door Handles - $10/Ea
Fender Liners - $20/Ea
Rear Bumper Shocks - $40/ea
Front Bumper Assy - $150
Front Bumper Shocks - $40/ea
Door Weather Stripping all four doors - $20/Ea
Rear Tail Lights - $30
Interior/Electrical/Stereo
Aftermarket cd player - $50.00
Climate Control - $75
Central Locking Pump (p/n 4A0 862 257 J) - $80
ECU - $75
Cruise Control Module - $30
Pillar Trims A,B,C - $30/ea
Trunk Carpet Complete - $50
Interior Carpet - N/A
Dash (Black) - $100
Passenger Air Bag - $75
Sunroof Switch Panel w/Lights - $50
Front Driver's Seat Pwr w/Lumbar, - N/A
Front Passenger Seat Manual - N/A
Rear Seat - N/A
Center Console Black (no Armrest cover) - $30
Door Pulls Black (no switches) Good Condition! - $40/Ea
Sunvisors - $20/Ea
Column Switches/Stalks $30/ea
Window Switches - $10/Ea
Interior Door Handles Black/Silver Good Condition - $30/Ea
Kick Panels - $20/Ea
Heater Box Complete w/Heater Core, A/C Evaporator and Fan Motor - $80
Rear Window Deck w/3rd Brake Light - $50
Tilt Steering Assy. w/ignition and Key - $60
Center Heater Vents - $15/Ea
Side Vents - $15/Ea
Rear Vents - $15/Ea
Overhead Grab Handles - $10
Front Seat Belts - $50/Ea
Rear Seat Belts - $25/Ea
Engine
Throttle Body - $50
MAF w/Sensor - $65
Alternators - $50
Brake Booster - $50
Differential - $75
Wiper Motor - $30
Wiper Linkage - $40
Fuel Pump - $75
Brakes/Suspension
Brake Booster - $25
Control Arms $40/ea
Differential - $100
Axle Rear - $45/EA
Axle Front - $45/EA
Headlights - $60/Ea
Hood - $150
ECU - $75
Dash (Black) - $100
Rear Seat - N/A
Sunvisors - $20/Ea
Side Vents - $15/Ea
Rear Vents - $15/Ea
RE: B5 A4 *PARTING OUT* EXTREMLY CHEAP
when you say fender liners do you mean the lower valences?? the unpainted black plastic parts?/
Do you have the glass from the driver and passenger side mirrors? Do you know if these would fit on a 98 A4?
Would you possibly have the rear passenger side reading light? If so, how much shipped to 89410?
i need the driver side washer sprayer cap thats on the bumper just below the headkight..your car is silver right?
Interested in power steering pump and hoses. How much to 38506?
i need the horns...how much shipped to 33781?
I am interested in the comfort control module. Is it still available? Will it work in a 99?
looking for passanger side door moldings, thanks
i got dibs on the passenger side molding iff accord96 doesnt take it.
