Quattro Auto B5 PARTS! Pistons, Extreme TIP, and GIAC!!!!!!!!
Sold my car and have a few parts left over.
The ECU is out of my 97 B5 1.8T Quattro automatic.
The last four numbers is 557N
Make an offer!!!!
[IMG]local://upfiles/45257/C49E84B674AE47C8870F278822284620.jpg[/IMG]
[IMG]local://upfiles/45257/8167C6CB8CCF4615A911B86F9FCB9F88.jpg[/IMG]
[IMG]local://upfiles/45257/6D66DCA5F3F944D79C9C5FB90DF0DDB5.jpg[/IMG]
[IMG]local://upfiles/45257/AF1A5FC371C94022A118CEBE7E2D2DE0.jpg[/IMG]
SET of JE Pistons - 83mm bore,9:1 CR $550 BRAND NEW!!!!!!
Brand New Nuespeed TIP (Black) $220
Make an offer!!!!
can you vag-com it for manual? (93 oct?)
I know it is possible to do. My question was if you were willing to do so before it is shipped.
Pictures not working. Interested in ECU.
Interested in pistons... wtf is the extreme tip
DEF want the GIAC too... Ill check multiple times a day, Tell me about the pistons
It does not have the reducer to hook to the stock turbo, it will fit a turbo upgrade. You can also buy the adapter from someone else. The pipe is new in box. Send me a pm if you have any more questions.
I just actually checked the box for the pistons, and the info that Issam gave me was incorrect. Here is the correct information.
Bore 3.268
Comp Height 1.286
Forging 81M
Pin Dia .787
Pin Length 2.250
JE .050 Wire Locks
Dish- .095
Top Ring 1.0mm
2nd Ring 1.2mm
Oil Ring 2.8mm
Actual Weight 313
Bore 3.268
Comp Height 1.286
Forging 81M
Pin Dia .787
Pin Length 2.250
JE .050 Wire Locks
Dish- .095
Top Ring 1.0mm
2nd Ring 1.2mm
Oil Ring 2.8mm
Actual Weight 313
Audi Forums Editor
03-04-2014 09:08 AM
junkeravant
09-26-2011 02:06 PM
