list of everything i cud think of from 98 a4
all from 98 a4 i figured id make the best list i cud at the moment
of everything
grab handles 40
for all 4
gray seats all in perfect condition except for drivers seat bolster has little tear whole set 2 front and rear 500
Air bags drivers and passenger 300
rear center console 50
upper center councoul set up heated mirror buttons rear defroster button and hazards HVAC and stereo 200
steering wheel 30
headliner 100
trunk cd changer and compartment that holds it 125
cruise control module 50
air bag sensor 50
instrument cluster 100
dash board 250
vents 15 for right side
audi manuals with case 50
ecu 150
glove box with nee bolster 130
left side nee bolster 80
dash board reinforcement bar 250
heater core 50
seat belts all front and back 200
sun visors 30each
small middle sunblock visor 20
foot rest 20
all the lining for the trunk 150
rear deck 100
center councoul outlining with front ash tray and cigarette lighter 75
front window 100
back window 500
brand new aeb head 600
straight block just block pistons and crank shaft oil pan and some pulleys 400
radiater with the front reinforcment 200
transmission with 0 miles on it from 1.8t tip tronic 2500 firm
suspension 150
axles 30 each
rims with peralie tires that are almost brand new with warrenty 500
throttle body 100
k03 turbo 100
turbo manifold 50
intake mani 50
full eaxuast cat back 250
water outlet housing 5 bux
fuel rail 50
coils 50 oil cooler 45
starter 50
alternator 100
stock fuel injectors 200
engine cover 20 bux
rear bumoer 250
left front fender 100
right front fender 100
hood with audi grill 350
truk 250
all the doors with perfect interrior 750
drive shaft 250
sunroof with mounts and motor 350
tail lights 100
all other sngine **** 200
door moldings with gray interrior on it 50
ask for pics if needed
of everything
grab handles 40
for all 4
steering wheel 30
headliner 100
air bag sensor 50
dash board 250
ecu 150
heater core 50
sun visors 30each
foot rest 20
rear deck 100
front window 100
back window 500
suspension 150
axles 30 each
throttle body 100
k03 turbo 100
turbo manifold 50
intake mani 50
fuel rail 50
starter 50
alternator 100
engine cover 20 bux
rear bumoer 250
truk 250
drive shaft 250
tail lights 100
could you send me or post a picture of the door moldings? are they the lower rubber ones? how much and are you willing to ship?
thanks
thanks
Interested in K03 if no cracks in compressor, center or turbine housings, no shaft play and seals intact.
mine has shaft play
what size are the rims?
Do you have the metal gaurd plate for under the oil pan?
I'd like the turbo
I know you said it had shaft play but if the blades are good and the housing isnt cracked I'd like it
Pete 901 289 3703
Pete 901 289 3703
hello i was wondering if it was an aftermarket cat back exhaust or a stock one?
thanks
thanks
are you parting out the whole car? you have the ignition control module or coil packs? i need a few for backup. send me a PM if they are available, thanks.
wondering if you had the intermediate shaft bearing, very similar to a camshaft bearing
