FS: Parting out B5 99 A4Q 1.8T Tiptronic Santorin Blue/Ecru
Prices do not include shipping.
Pics Available upon Request.
If you don't see it….Ask, I probably have it!!!!
FASTER Response if you email direct for pics or questions to MPLSChase@gmail.com
All parts tested/inspected and only good parts sold!!!
Feel free to check out my feedback: http://www.audizine.com/forum/showthread.php?t=130524, and if you buy something and are happy please leave me some. I will always work with you if there is an issue and guarantee no DOA! Thanks!
The Car had 100K on it had driver side damage...The engine had 20K on it from an Audy Factory Rebuild...I will post engine piece prices seperately, ask if you need anything...
Engine
Turbo - Sold
Tiptronic Tranny Code "DTV" (bell housing damage, for parts) - $300
A/C Compressor - $50
Starter - $50
Alternator Amp - 120 Amp - $50
Power Steering Pump - $30
Intercooler Side Mount - $50
Oil Cooler - $30
Differential - $100
Radiator - $60
Belly Pan - Sold
Exhaust System - Borla Cat Back- $500
O2 Sensors - $40/ea
Coolant Resevoir w/sender - $30
Wiper Motor - $30
Air Filter Box - $30
Air Filter Box Duct - $20
Fuel Pump - $75
Drive Shaft w/Carrier Bearing - $100
Brakes/Suspension
Steering Rack (Koyo) - $150
Outer Tie Rod ends - $40/ea
Inner Tie Rod ends - $40/ea
Eibach Pro Kit Lowering Springs (1534) W/Stock Struts/Shocks (4 Shocks/4 Springs) - $250
Control Arms - $40/ea
Differential - $100
Axle Rear - 2/Ea $50/EA
Axle Front - Passenger Side Only - $50
Rear Hubs/Knee Assy - $50/ea
ABS Speed Sensors - $50/EA
Brake Booster - $60
Brake Master Cylinder - $60
Brake Fluid Resevoir - $25
ABS Pump - No Module - $50
Brake Calipers - (4) $25/EA
Exterior/Body/Lighting
Trunk (Santorin Blue) - $150
Door PS Frt (Santorin Blue) - $150
Door PS Rear (Santorin Blue) - $150
Fender PS (Santorin Blue) - $75
Fender Liner (Passenger Front and both rears) - $20/ea
Door Mouldings Passenger Side Mid (Pelican Blue) - $40/Ea
Moon Roof Assy Complete (Glass) - Ecru Interior Shade - $100
Rear Bumper Cover w/painted Lower Valance (Santorin Blue) - $150
Rear Bumper Shocks - $40/ea
Door Weather Stripping all four doors - Ecru Trim $40/EA
Interior/Electrical/Stereo
Concert Bose Stereo w/code - $80
Bose Amp - $50
Bose Speakers:
- Front w/tweeter - $50
- Rear Deck - $60
- Rear Door - $40
Pillar Trims A,B,C(Ecru) - $30/ea
Headliner Grey for Sunroof (Ecru) - $100
Interior Carpet (Black) - $80
Sunroof Switch Panel w/Lights (Ecru) - $40
Center Console Black (no Armrest cover) - $30
Sunvisors (Ecru) - $25/ea
Column Switches Both sides $60
Window Switches - $10/Ea
Sunroof Motor - $75
Window Motors - $50/Ea
Window Regulators - $50/Ea
Kick Panel (Ecru) - $20/Ea
Lower Door Sill - $40
Heater Box Complete w/Heater Core, A/C Eaporator and Fan Motor - $100
Rear Window Deck (Ecru) w/3rd Brake Light $50
Tilt Steering Assy. w/ignition Key - $60
Center Heater Vents - $20
Side Vents - $20
Rear Vents - $20
Overhead Grab Handles (Ecru) - $10[/align]
Engine
Turbo - Sold
Starter - $50
Oil Cooler - $30
Differential - $100
Radiator - $60
Belly Pan - Sold
O2 Sensors - $40/ea
Wiper Motor - $30
Fuel Pump - $75
Brakes/Suspension
Differential - $100
Brake Booster - $60
Bose Amp - $50
Bose Speakers:
- Rear Deck - $60
- Rear Door - $40
Sunroof Motor - $75
Side Vents - $20
Rear Vents - $20
RE: FS: Parting out B5 99 A4Q 1.8T Tiptronic Santorin Blue/Ecru
Does the Exhaust System - Borla Cat Back- come with the downpipe? Also how old is it?
ORIGINAL: fendergtars
Lots of parts left!!!
will your abs pump work on a 99.5 a4 quattro 1.8t manual?
ORIGINAL: B5 SLPR
tranny pan and oil pan
ORIGINAL: sonex2000
Is the stereo a cd player?
i need a heads up diplay modual and a keyless entre modual with fobs if you got um
