completely built 2.7 motor tial 770s.. MORE
034 built the motor, all it needs is thrust bearings and its coming to me in louisiana... was going to put it in my s4 but things came up and really just cant do it anymore.... shoot me offers in a email or text
email- dcur333@yahoo.com phone# - 9857073027
HEAD STUD KIT, AUDI 2.7T RWE-1051
HEAD GASKET, 2.7T UP TO 83.5MM BORE
OEM VALVE COVER GASKET SET, ONE VALVE COVER, AUDI 2.7 2.8
TIMING BELT KIT, 2.7TT
2.7T HIGH LIFT VALVE SPRING SET WITH RAISED INSTALL HEIGHT, INCLUDES TI
RETAINERS.
MAIN STUD KIT 2.7TT, SAME LENGTH STUDS, LATE 2001 RWE-2015 1 345.00
PAUTER 2.7T ROD SET 1
COATED MAIN BEARING SET, GLYCO, AUDI V6
AUDI V6 ROD BEARING SET, COATED
JE FORGED PISTON SET, 2.7T, 82.5MM BORE, 86.4MM STROKE, 9.0:1 COMPRESSION RATIO
BOTTOM END BORE/ASSEMBLY
TIAL GT TURBO KIT, INCLUDES ALL COMPONENTS AND UPGRADED GARRETT GT
TURBOS FOR 770HP
INLET PIPE SET FOR TIAL 605/770 TURBO KIT 1
2.7tt Tilton flywheel for 01E applications with 2-disc cerimetallic, or 3-disc sintered iron clutch
kits.
TILTON PRESSURE PLATE FOR TRIPPLE DISC SINTERED IRON 7.25" CLUTCH KIT, 950 ft/lb RATING.
TILTON 2 PLATE CERAMETALLIC CLUTCH PACK FOR 01A/01E SPLINE FOR AUDI/VW
TRANSMISSIONS
THROW OUT BEARING ASSEMBLY FOR 7.25" RACE CLUTCH KITS IN AUDI 01A/01E.
TILTON RELEASE BEARING, INCLUDES BILLET ALUMINUM HOUSING
SINGLE 044 SURGE TANK, FP34, TANK INCLUDES q3-12MM PLUGS W/ WASHERS,
PUMP
***NIPPLE FITTINGS/ CLAMPING FEET***
72LB OR 750CC EV14 BOSCH INJECTOR
INJECTOR ADAPTER TO CONVERT S4 2.7T FUEL RAIL TO RS4 INJECTORS
INJECTOR CONNECTOR ADAPTER, BOSCH TO USCAR, FOR GENESIS 750CC
INJECTORS
RS4 SILICONE MAF HOSE, BLACK
85MM 2.7T MAF, HOSE CONNECTIONS, HO MAF
HO MAF SENSOR/ CONNECTOR
034EFI CHIP TUNING, B5 S4 - TIAL 770 KIT, BASEMAP
DOWNPIPE PAIR, B5 S4 3" TIAL 770
WITH WASTEGATE REROUTES BACK TO DOWNPIPE
RETAINERS.
TURBOS FOR 770HP
kits.
TRANSMISSIONS
PUMP
INJECTORS
This is my fist post
PUMP
PUMP
Whare are the pics?
Dylan Cure
07-13-2014 09:09 AM
Dylan Cure
10
08-30-2013 01:25 AM
