B6 1.8T Speedtuning ECU
its an ecu i couldnt get working for me. i paid oliver at speedtuning to flash the ecu with the 1 Bar PSI chip.
got it back and the fuel system would pressure up and car would not recognize
sent it in again, and just got it back. now the fuel rail pressures but injectors wont fire... no visible damage?
he said to send it in again and he would look at it
im sick of messing with this so i bought a new stock ecu and REVO stae II flashed it.
it worked when i pulled it out. <b> $75.00 will ship anywhere in us
RE: B6 1.8T Speedtuning ECU
so the ecu doesn't work? or you got it working right before you pulled it out? also, will it work with a 5spd? what other things would i need to get it to work?
if i knew what i needed to do to it to get it working i would of done it . everything works except the car doesn start. lol in injectors wont fire. and the only thing that runs the injectors is the ECU. so....!? its a chipped and tuned ECU that never worked rightafter oliver messed with it. as for the 5spd. check my sig.... car is a 5spd
