APR R1 Diverter Vavle/ATP Inlet Pipe/ATP T3 Manifold/Injectors/T3 Turbo
Was going to build my parts car into a track car but I have just given up on ever having the time. Here are the parts I had bought from a local wholesaler here in miami.
-Turbosh T3 Turbo $225 *NEW*
-.48 AR Turbine
-.50 ARp Compressor
-T3 Flange
-ATP T3 Flange Manifold w/ External Wastegate Flange $200 *NEW*
**ATP website** "ATP cast iron manifold designed for T25 or T3, T3/T4 turbo applications. Will work on any 20v 1.8T motor. Applications include VW Golf/Jetta IV, VW New Beetle, Audi TT, Seat Leon, Audi A3, Audi A4, Passat, and Audi S3. Hi-temp cast iron 1/4" walls prevent cracking under severe heat. Precisely drilled for head studs and threaded (8mm x 1.25" for T25/GT28R/RS or 10mm x 1.5 for T3/GT30R/GT35R) for either T25 or T3 inlet bolt patterns. *Cast with external wastegate flange, but can be blocked off with blockoff flange for integral wastegate setups. Specify T3 Flange or T25/T28/GT28R/GT28RS Flange"
-ATP Inlet Pipe $150
**ATP website** Large bore 3" inlet pipe upgrade for eliminator series, Stage II Turbos utilizing stock location manifold. Totally "hard pipe" system does not collapse under boost like rubber or silicone. Full 3" diameter throughout and does not taper towards the turbo*. O-ringed to provide an air-tight seal.
-Siemens 630cc Deka Injectors $150
-Bosch 440cc "Green Top" Injectors $100 SOLD!
-35mm JDM Wastegate 7 psi spring $60 *NEW*
-35/38mm Wastegate dumptube with gasket/screws $30 *NEW*
-JDM Oil Return Line kit to support Turbo Upgrade $40 *NEW*
-.48 AR Turbine
-.50 ARp Compressor
-T3 Flange
APR R1 relisted. Still Available.
Sorry I jumped the gun Wife took all my money. Great buy though.
sorry about that.....
bump everything still for sale.
text me....i want everything....787-344-4265
picture sent
Do u still have everything for sale?
oh and are you in LA area?
