Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
ticking sound from engine
Old 06-12-2011 | 10:44 PM
chriswillis's Avatar
Default ticking sound from engine
I have a 02 allroad with a ticking sound an a flashing check engine light that giving a miss fire code i replaced all the plugs an coil packs an ignition module an the cam shaft sensor all these parts popped up an i still have the ticking sound an miss fire code is still coming on also smell oil burning can anyone help thanks.
Old 06-13-2011 | 01:11 PM
swamper8's Avatar
If you still have a misfire coming up after replacing all those parts you may want to do a general health check of the engine. I.E. a compression test would be a great place to start, followed by a cylinder leak down test and/or a block test. You can get a compression tester for not much money at your local Auto parts store or buy one online. I like to do a compression test when the engine is cold and then again when it's warmed up.
You said you only replaced one ICM? You may be unlucky enough to have replaced the wrong one. (as there's two) Try swapping the ICM's and see if the misfire moves to a different cylinder. If it moves you know you have a bad ICM. If it stays at the same cylinder than it's not the ICM. The two conditions (misfire/ticking) may be unrelated in that the other ICM is bad (misfire) and ticking is just some worn out components due to low oil or in frequent oil changes.
You may also have a fuel injector crapping out on you causing a lean and/or rich condition at your misfiring cylinder.
Others may chime in as to maybe a clogged PCV system? Something to think about. Smelling oil could be a leaking gasket and it's hitting the hot block or you could be burning oil in which case the smell would be coming more from the tailpipe.
Old 06-14-2011 | 08:40 PM
Thanks alot one of the icm was already replaced so thats why I only replaced one but my mech said it was a vacuum hose leak.
yellow_submarine
10-19-2011 01:02 PM
redsapphire89
12-10-2007 11:44 PM
droo587
04-10-2007 06:41 PM
