Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Spacer for stock wheels
Old 04-27-2011 | 01:37 PM
vtraudt's Avatar
Default Spacer for stock wheels
To bring the edge of the tires (edge=end of tread, rounding into the side) flush with the fender extensions, I want to use spacers on the stock wheels.
This setup has been proven to provide (IMO!) the best stance (followed this guideline on various cars, including A4 which sits 'perfect').
How much can be added with 'spacers + extended bolts', and when are 'adapters' (bolt to the hub, wheels bolt to adapter) needed?
I haven't measured yet (does anyone have the dimension?) how much 'space' I need.
Old 06-05-2011 | 01:59 AM
Zachariah's Avatar
20mm spacers with 48mm bolts should do the trick....
Old 06-05-2011 | 10:40 AM
vtraudt's Avatar
I installed for my stock Allroad double spoke wheels:
20mm hubcentric spacers, 45mm bolts front (worked, no rubbing)
20mm hubcentric spacers, 50mm bolts rear: bolts to long, locking wheel. Ground down to ca. 47mm. Worked, no rubbing.
Result: tire sidewalls not entirely flush with fender edge (probably another 5mm?), but it allows me run a bit lower since the tire edge still tucks inside the fender. If fully flush, it would likely rub on the fender at the current lowered setting.
Old 06-06-2011 | 10:19 AM
Zachariah's Avatar
Default Looks Good!
Excellent. Now, get some cheap ECS mudflaps, to complete the wide stance look!
HockeyA6
04-04-2014 08:10 PM
bigatstyle
11-09-2012 09:29 AM
DerrickS
11-15-2008 12:48 PM
ltsheets
04-24-2008 08:16 AM
n0dn4rb
01-26-2007 03:31 AM
