Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
402 Suspension Mod
Old 09-20-2008, 06:05 PM
ccomengee86's Avatar
I think the ride height at level 2 is still lower than factory spec level 1. So the ride quality at the level 2 is about the same as factory spec level 1.
Factory spec level 1 on the rough roads? I dont think so.
When I did the 402 mod(15mm in front) I had less than an inch and a half clearance. I personally wouldnt go any higher than 15mm but there are people with 20mmF&R.
If you want the look, just put the car on level 1 when parking and drive in level 2.
Use this website to find Vagcom in your area.
http://vagcomlocator.com
Just to give you an idea,
http://farm4.static.flickr.com/3061/...99e7309d_o.jpg
Old 09-21-2008, 07:15 AM
billvt's Avatar
Thank you very much ccomengee86. Your information is very helpful and the link to the Vag-Com locator is much appreciated. I think I will try dropping the level by 15mm front and 12mm rear and use Level 1 for smooth roads. Then I'll use Level 2 for everything else like I now use Level 1.
Old 09-21-2008, 08:08 PM
incrementalg's Avatar
Personally, I think lowered allroads look out of balance. With the fender flares and the bumpers being so prominent, I think they look a little top heavy when lowered. (like there's too much sitting down on the wheels)
There's a black ar that I see pretty regularly that's lowered with 18's and looks like its squatting down on the wheels and spilling out over them.
Old 09-22-2008, 02:36 PM
Keep in mind that if you were to reverse the 402 mod, it WILL take numerous times to undo the mod as the process often fails(to calibrate).
Old 12-31-2008, 12:45 AM
allroadnasty's Avatar
i did the 402 mod and successfully lowered mine 30mm front and back...
i also put 225/45/17 barum bravuis' on her, when i have used this forum a lil more and i figure out how to do things i will post pics...
i think i am going to completly APR tune my AR when i return from my soon coming REdeployment to iraq with the us army
Old 01-13-2009, 02:04 AM
i would never do that to mine. that would definitely kill the air bags in the long run.
IMO that's extremely low. i doubt bags can handle that much pressure(due to the weight on bags).
i dont know whether you've read the direction or not, but i can assure you that it would do no good on your bags.
(recommended settings are between 10-20mm)
luxuryimports1
06-23-2009 11:11 AM
ggoodling
11-11-2007 04:34 PM
i_baked_cookies
04-25-2007 02:52 AM
Quick Reply: 402 Suspension Mod
