1993 Audi 100 CS Quattro V6 Bose Radio
Hi. I just replaced the battery on my '93 100 quattro v6. Afterwards the stock Bose radio/cassette playerwent to a SAFE mode and it will not play or do anything. Is there a way to "unlock"the radioor bypass it somehow? I am not the original owner, so if there is a code or something I never got it. Do I have any other option or should I take it to the dealer?
Thanks!
Thanks!
RE: 1993 Audi 100 CS Quattro V6 Bose Radio
Thanks for the suggestions. I don't seethe codeanywhere. I tried to remove the radio without success. DoI need some special tool? Its the original Bose radio/cassette unit. It has 4 small holes in the corners. I'm thinking that a special tool goes in there for removal.
ORIGINAL: msa10
Did you disconnect everything from behind?
the 4 small holes might suggest the necessety of a special tool .. it looks like a U and it comes in pairs ... you could acctually stick some thicker wire in thhose holes and than see if the inside tabs come loose
http://www.crutchfield.com/S-U83vJ0L...;display=L#Tab
