Burned 1 quart in 5K miles?
Old Sep 8, 2008 | 05:15 PM
phosphateb's Avatar
Default Burned 1 quart in 5K miles?
Guys got 20k on my b7 and had to put a quart of oil in at after the 15k audi care mandatory oil change? I have not driven the car hard had but may be doing something stupid so will pose the question here: If you go down a long hill and put the car in neutral and coast at a high speed does it cause any issues? thanks!
Old Sep 8, 2008 | 07:15 PM
dmfan016's Avatar
no...it saves a lot of gas tho
and did you check your oil when your car was hot or cold?.....cause after you drive it your oil may ''appear'' low when really it hasn;t settled back into the pan yet
Old Sep 8, 2008 | 08:01 PM
eMacPaul's Avatar
Does it save gas? If you're in neutral it's going to be at idle throttle, and unless your foot is on the gas it should be at idle anyway. If you're in gear, it might not even need to have any throttle to keep at idle RPM.
Old Sep 8, 2008 | 08:07 PM
auditech79's Avatar
I believe audi finally released a TSB repair about excessive oil consumption on the 2.0T engine. It has to do with the PCV valve assembly. You might want to take it to the dealer and have them run an oil consumption test, or they might have authorization now a days to just repair it.
Old Sep 9, 2008 | 12:13 AM
dmfan016's Avatar
i drove a tank a gas the whole time in gear and whole tank coasting in nuetral and i got 250 miles and 320 respectivly....idk its always worked for me
Old Sep 9, 2008 | 12:19 AM
harryd14's Avatar
yeah i always find coasting saves me a noticable about of gas
Old Sep 9, 2008 | 08:43 AM
phosphateb's Avatar
Hey guys thanks! I am glad the coasting does save gas mileage when i shift into neutral and the rpms go down to 6-8k. Also appreciate knowing it doesnt bother the turbo.
regards
Old Sep 9, 2008 | 08:52 AM
dmfan016's Avatar
if u wanna save more gas don't go higher then 2700-3000 rpms at all.....its not a high enough RPM to properly spool up the turbo therefore you use less gas because there is no forced induction
its not bad for your car but you won't have that pep you would normally have around like 3500-6000 rpm
Old Sep 10, 2008 | 07:20 PM
phosphateb's Avatar
Thank you for the great information. I will keep that in mind during every fill up....and once in a while exercise the turbo ;-)
Old Sep 12, 2008 | 07:19 PM
harryd14's Avatar
yeah, always good to make sure that turbo is goin strong for that late night race here or there!
