Rear speakers 2000 A4 1.8T Quattro
Old Nov 20, 2009 | 10:41 AM
gstevens26's Avatar
Default Rear speakers 2000 A4 1.8T Quattro
I understand the rear speakers are powered by a little amp. I wondered if it's possible to replace the rear speakers with aftermarket ones and have them powered off this amp?
Old Nov 20, 2009 | 03:13 PM
collins's Avatar
just make sure theyre 2 ohm speakers and you can wire them up the same
Old Nov 20, 2009 | 04:51 PM
TeeterTawter's Avatar
he can run 4ohms with no issues. thats what i did, then i got a 4ch amp and all my ***** now running from the 4 ch amp with stock head unit.
Old Nov 25, 2009 | 12:42 AM
M3Armand's Avatar
Don't bother... been there... done that... it don't work as planned. The little amp is just that... too little. I ended up putting the stock speakers back since they are "matched" correctly to the amp and head unit. With the aftermarket speakers I got, the amp simply wasn't strong enough to drive it.
Old Nov 25, 2009 | 09:50 AM
snsamotors's Avatar
get the rca box.... where you connect it to the rear speaker into a amp and hook up a system.
my car scream with a stock headunit. i got 2 amp (need more) one to power my sub and another one to power my high. i'll post a picture of my setup if you wanna see how to do it.
Old Nov 25, 2009 | 05:08 PM
ObnoxiousDrunk's Avatar
It is possible, I just did this exact swap this past weekend. I re-used the soldering points from the stock speaker for the aftermarkets. Just solder the red and black wires where the stock speaker wires were and replug the connectors and you're golden. I wasn't able to get the amp to fit over the speaker magnet like on the stock one, I just flipped it around and double side taped it to the speaker, easiest way I found to keep the amp connector for the speaker.
You will have to work around how to fit the aftermarket speakers in the spaces though, I had to heavy modify my aftermarket speakers to fit in the stock housing (yeah I had to cut that off the old speaker as well).
It's not as hard as it seems, just a little time consuming.
Old Nov 26, 2009 | 06:33 AM
gstevens26's Avatar
Yeh please mate. Pics would be good. Think i'm gonna replace the rear speakers and wire in an after market amp using the the speaker cabling from the head unit and use one of those converters that switch the signal to low level so you can connect via rca to the amp. Then gonna use that amp to power the new rears, sub and hopefully new front components.
Any guides or pics on doing this would be greatly appreciated and would appreciate any suggestions on rear speaker replacements. Not sure whether to go for components or a coaxials...
Old Oct 22, 2013 | 11:45 PM
NewaudiA4's Avatar
So how do I hook up the rear stock speakers again?? There are two wires disconnected from after I diconnected the subs that were back there.
Inferno451
Jul 23, 2015 01:15 PM
randylwjr
May 9, 2012 07:30 PM
princeking
Aug 8, 2009 06:15 PM
v6audi
May 13, 2009 03:37 AM
AmadiAudiA4
Aug 15, 2008 11:31 PM
