Cold start Idle Bounce (2-4 times)
Old 11-12-2009, 09:17 AM
Jackmup's Avatar
Default Cold start Idle Bounce (2-4 times)
2000 4.2
On cold start the idle bounces 2-4 times from 600-1400 rpm then levels off at 1200 or so for warm-up and kick down when warm fine. After that there's no trouble and it starts fine when warm no bounce. Only in cold start.
I replaced the MAF, Temp sensor, and all Vacuum lines. The vac system is holding vacuum. Lambda is 0.0% on all four after warm-up.
I have these two codes - but no CEL
P1564 Throttle actuator(J338) under voltage during basic setting - intermittent
P1141 Load Calculation cross check - implausible
any suggestions?
Old 11-12-2009, 02:23 PM
Midniteoyl's Avatar
Throttle Body most likely.. have you re-adapted?
Also, apparently you can pull it apart and hit with contact cleaner:
http://tech.bentleypublishers.com/th...41526&tstart=0
Old 11-12-2009, 03:21 PM
auditech79's Avatar
Agreed, do a throttle body adaption.
Old 11-12-2009, 11:52 PM
Jackmup's Avatar
That was the first thing I tried, no success.
So going of the "under voltage" DTC I pulled the terminal off and cleaned it, Nothing. Then I pulled the side cover off
took a nail file to the top two terminals ans sprayed the rest with MAF cleaner and just tweaked the four lower terminals.
For those that need pictures (midniteoyl) Please scroll down.
I did mine with the TB on the manifold. I don't know if you can do them all that way. Stuff shop rags around it before popping the clips or you'll be sorry!
One of the clips
The upper terminals I cleaned with a nail file. Blow out the filings with air!
The lower ones I sprayed and bent them out very slightly so they make good contact.
The cover I sprayed
The cold start idle bounce and the surge while driving is gone. Acceleration from a stop is much smoother.
Old 11-13-2009, 12:30 AM
Midniteoyl's Avatar
COOL!
Whats wrong with wanting pics?
Old 11-23-2011, 03:08 AM
rudia8's Avatar
Default Audi A8 idle bounce
Thank You Jackem Up...I did what you posted and the pics along with your tips helped me do the job and IT WORKED..NO MORE BOUNCY IDLE!! Getting the clips off and back on is the trickiest part of the job...one thing I did was to put strips of blue painters tape on them which allowed me to retain them once I popped them off the sensor and also helped me reposition them when putting everything back together..duct tape might be better. Anyway thank you so much for posting what you did..it solved my problem!!!
Old 01-08-2012, 12:56 AM
Jackmup's Avatar
I just saw that.
Great !
That should cancel one of those bad things I've done somewhere
Lord knows I been paying homage to the GM Mechanic gods lately.
jeckel20003
02-24-2014 05:24 PM
Jackmup
11-13-2012 12:17 PM
dave72
09-07-2011 04:22 AM
burtonboarder84
03-04-2010 06:44 PM
kaotik411
12-26-2007 10:10 AM
Quick Reply: Cold start Idle Bounce (2-4 times)
